danishdeshmuk
Advanced Member level 1
I want to prepare/create/build an electronic card which is used to provide the variable DC voltages from 0 V DC to 30 VDC of 5 Amps to 6 Amps automatically in such a way that when the web film roll has the bigger or larger diameter the card should provide larger or maximum output DC Voltage & Amps and as the diameter (circumference) of the web film roll keeps on decreasing the DC voltages & the amps also decreased with that till 6 to 8 V DCs.
Kindly provide me the circuit schematic of this Automatic controller' PCB ??
The output of this would be connected to the Magnetic Powder Clutch Brake set up .....
I think it may be a some kind of Automatic Tension Controller ........
thanks
take care
thanks
take care
