AzharElectronics
Junior Member level 2
Hi All,
I have a substance which measures mili ohm (around 40 mili-ohm) resistance and due to its face wear the resistance changes.
Wear out causes change in resistance of few micro ohms (around 70 micro-ohm). And I wanted to measure this change in resistance using some electronics circuit.
Initially I tried using Wheatstone Bridge but I was not able succeed. Later when I did some study online I got to know Kelvins double bridge is used to measure low resistances.
My subject material (substance) can be four wired. Hence I wanted to know how these four wire can be connected in Kelvins double bridge ?
Whether using Kelvins double bridge is suitable or some other technique is available to measure change in micro ohm resistance ? please let me know that other technique if available.
Also If we are using Kelvins double bridge how practically I need to balance the second arm of Kelvins double bridge ?
A Picture diagram will help.
Thanks & Regards,
Azhar
Thanks & Regards,
Azhar
