keil C programing problem
satya_vijayawada
Full Member level 2
Full Member level 2
does keilc supports float values
hi
iam using keil software for 8051 series
in C programing Float values not supported
help me
satya
this is due toi the fact that you are using eval version.
eval version dose not support code above 2k and floating point support.
hock
Hi
If you are satisfide with the eval version anddon't need to pay
you can read IEEE 745 and implement foating point operations you need by your self.
Work more and pay less or pay more and work less
Salam
Hossam Alzomor
www.i-g.org
iam using full version keil s/w.
but floating point not working
have you purchased in?
if that is the case look for support from your distributor.
many full downloadable version do not have the full floating point lib.
hock
