Jameskennymatheson
Newbie
I only post the very best
I learned a battery can stay 45c forever
Charging lithium-ion battery is possible in a temperature range of 10°C to +55°C. However, the charging should take place only at a battery temperature of +5°C to +45°C."
Same as leaving it plugged in a wall
Its best to use a watch battery li ion then the liquid because the liquid is very flammable
It can be kept powered using a 20ma hand crank like this:
https://www.creatroninc.com/?s=Hand...ributes=1&tags=1&sku=1&orderby=ID-ASC&ixwps=1
All you need is s small motor and thermistor on a coin lithium rechargeable battery to prove this
Here's another article saying it is possible
This will let people have 45c everywhere
All thats needed is to put the coin battery on a heat pipe and the heat can be sent a further distance
We dont have temperature control switches where i live
We need this device
If anyone can make this we need several billions of units
Endlessly
Hopefully someone is interested
We need this device
Endlessly
