Johan Wevers' Physics & Maths Formulary
sathishkrishna
Newbie level 6
Newbie level 6
This document contains a 108 page LATEX file which contains a lot equations in physics. It is written at advanced
undergraduate/postgraduate level. It is intended to be a short reference for anyone who works with physics and
often needs to look up equations.
This, and a Dutch version of this file, can be obtained from the author, Johan Wevers
(johanw@vulcan.xs4all.nl).
It can also be obtained on the WWW. See https://www.xs4all.nl/˜johanw/index.html, where
also a Postscript version is available.
If you find any errors or have any comments, please let me know. I am always open for suggestions and
possible corrections to the physics formulary.
This document is Copyright 1995, 1998 by J.C.A. Wevers. All rights are reserved. Permission to use, copy
and distribute this unmodified document by any means and for any purpose except profit purposes is hereby
granted. Reproducing this document by any means, included, but not limited to, printing, copying existing
prints, publishing by electronic or other means, implies full agreement to the above non-profit-use clause,
unless upon explicit prior written permission of the author.
This document is provided by the author “as is”, with all its faults. Any express or implied warranties, including,
but not limited to, any implied warranties of merchantability, accuracy, or fitness for any particular
purpose, are disclaimed. If you use the information in this document, in any way, you do so at your own risk.
The Physics Formulary is made with teTEX. This pdf file is made with pdfTEX.
I found this here:
Code:https://www.101science.com/physicspage2.htm
DL:
https://www.xs4all.nl/~johanw/physics-hyperref.pdf
https://www.xs4all.nl/~johanw/math-hyperref-letter.pdf
Check his site out for other versions and other stuff:
[codehttp://www.xs4all.nl/~johanw/[/code]
exactly what kind of physics does it stress upon?
