Jitter attenuator with HCSL output
Romanp
Member level 4
Member level 4
Friends,
Advice please.
PCI Express card get SSC 100 MHz clock and converts it into 125 low jitter clock.
Problem is schematic. Suggested component (by xilinx) has 6 LVDS outputs. Case TSSOP28.
I would want to use component with only 2 differential outputs. Pproblem. Present component (ICS9DB202-01) has only 0.7V HCSL outputs. Minimum swing of requested LVDS or PECL driven inputs is around 750-800 mV.
How to work with HCSL?
