xambo
JFET 2n4393
Hi, I am new with JFETs. I want to incorporate a JFET 2N4393 to work as a voltage controlled resistor. I have two questions:
a) can I have it to work as a linear resistor? I learned from somewhere that if I put 1M resistor in the drain and a 1M resistor between drain and gate then the Vgs controls the Rds reasonably linearly. I think this is approximately true?
b) Just checked the resistance between Drain to source without connecting the component into the board and it shows 47Ohm! Is it supposed to be the case?
please let me know your valued comments soon.
