dipk11
Junior Member level 2
Hi i am new to using Jenkins CI/CD. I am using a Vnc server to connect to a remote Linux PC. I have a fpga project on gitlab which is cloned properly to my local repository. I used webhooks so that anything that is pushed inside the remote repository on the github, the jenkins script is triggered and the project is build.
Below is my jenkins script written in a Jenkinsfile which is a part of my project on the Gitlab.
This pipeline fails giving the below error.
16:36:08 Caused by: org.codehaus.groovy.runtime.InvokerInvocationException: org.jenkinsci.plugins.workflow.steps.MissingContextVariableException: Required context class hudson.FilePath is missing
16:36:08 Perhaps you forgot to surround the code with a step that provides this, such as: node
\nThis repository is configured for Git LFS but 'git-lfs' was not found on your path. If you no longer wish to use Git LFS, remove this hook by deleting .git/hooks/post-checkout.\n
I am unable to understand the error. Also if anybody here knows how to use jenkins pipeline, how can i change my workspace to a folder on my vnc machine \Results?
At present it is running on oulnxc58.emea.nsn-net.net in /userwork10/socci_lsf/jenkins-slaves/sochw-oulnxc58/workspace/Examples/test1
pipeline {
agent {
// runs on lsf
label 'grid'
options {
timestamps()
timeout(time: 800, unit: 'MINUTES')
buildDiscarder(logRotator(artifactDaysToKeepStr: '14', artifactNumToKeepStr: '7', daysToKeepStr: '14', numToKeepStr: '7'))
environment {
spyglass_git="${WORKSPACE}"
stages {
stage('Build and run') {
steps { // use shell commands
sh label: '', script: '''#!/bin/bash
module load lsf
module load spyglass/M_2017_03_SP2
bsub -Is -q i_soc_rh7 -R "rusage[mem=25600]" spyglass
source spyglass.tcl
post {
always {
script{
// when testcase fails
if(manager.logContains('.*failed at.*')) {
manager.addWarningBadge("Some FHSS testcases failed! Check logs for details.")
manager.buildFailure()
cleanWs()
