JDM programer pic16F84A error
the_kid25
Member level 3
Member level 3
thailand
please help me solve problems of writing ic PIC16F84A with ICprog106B always verifiying 000h error, I use the downloader JDM and my setup hardware interface:windows API I/O delay:4 detail pic in attch...
have you copied the driver for ICProg in the install folder of the ICProg (ok it's not a install folder its a copy folder)
and use Direct I/O, not Windows API
I/O delay about 10-20
try to chose PIC16F84 without the A on the end and try again
try to use WinPIC, test the Vpp voltage levels it should be from 10V to 13V
I have build this about 10 times and it works perfect
JDM PIC Programmer
    V
I've tried to use direct I / O and windows API but why still error.indikator Vpp when writing a blink-blink then goes off when finished writing and re-ignite and led CLK off and verifiying error000h.i using a cable with a length of 50 cm as well as fixed cable error . whereas for writing ic 24Cxx succses.why could happen with my PIC16F84A Ic blank data writing tests ok,What software in accordance with the above schematic
with this schematic i use ICProg its a JDM programmer, i have sometimes the same problem as you with this type of programmer
take off the LED's because you need all the power from the serial port for programming the PIC, try the WinPic software, there configure the hardware as JDM programmer and test it, there you have some test options
try to program another PIC to verify that the programmer is working good
what led must be removed LED Vpp or led 5Volt .
and whether there are modifications schematic so that the program is running perfectly.
I am very confused with this problem.:oops:
please help me
remove the led's on 5V and Vpp, remove the resistor and the led on the RTS pin
see this image
see this image
I already did your suggestion but why keep it in case of error.
even though the hardware test ok
what's hardware settings is wrong.
try to download correct icprog, some icprog s/w is not working well
if you want send your mail address, then I will send
the test is ok without load, but when you try to program the pic the voltage drops to a small level
I mailed S/w
check and reply
thank you I've received S/w 3.58 from your email.
but S/w failed to install drivers w800IO.sys
I also have S/w version 3.63c installed the driver ok and write for 24Cxx with this schematic ok but 16F84A error.
duh....i very2 dizzy....:sad:because been modifications and mutually exchange S/w still error if the write 16F84A
what OS you are using
what port you are using I mean DB 9 or LPT
I am using this S/W with XP without failure with DB 9 port
I am using Os win xp with DB 9 port via conector rj45 cable 40cm to DB 9 Female
Nice
check your ground line of DB9 connector, it should be totally disconnect with your cct ground
Nice
I have checked and not connected
when I have used my old ICD2 clone on the DB9, sometime i had some error messages, because the connector (DB9) was not connected on the GND pin, so try to connect it to gnd
results remain the same errors despite DB9 connected on the GND pin.
