keshav98765
Hi, I am working on SD Card interface with PIC18F4520 microcontroller. I am using Fatfs library.
The code is:
And I am getting error as:
Please Help.
The code is:
C:
#include <xc.h>
#include <string.h>
#include <stdio.h>
#include "fatfs.h"
#include "sdcard.h"
#include "uart.h"
#include <stdlib.h>
// holds partition 1 PBR address
unsigned long part1_addr;
// number of bytes per sector
unsigned char sector_size;
// number of sectors per cluster
unsigned char sectors_cluster;
// number of reserved sectors
unsigned char sectors_reserved;
// number of FAT copies
unsigned char FAT_copies;
// number of possible root entries
unsigned char root_entries;
// number of sectors per FAT
unsigned char sectors_FAT;
// FAT addresses
unsigned long FAT_address[2];
// root directory table start address
unsigned long rootdir_start;
// data region start address
unsigned long datareg_start;
// file specific variables
// starting cluster number of file
unsigned int cluster_number;
// starting sector of cluster address
unsigned long start_sector_address;
// sector address of current sector
unsigned long current_sector_address;
// current sector number
unsigned char current_sector = 0;
// entry address in root directory table
unsigned int entry_addr;
// number of byte in sector
unsigned int byte_number = 0;
// file length
unsigned long file_length = 0;
char address_buffer[10];
void mount_disk(void){
// read sector 0 (MBR) from card
SDcard_read_block(0x00000000);
// calculate address of partition 1 PBR (first sector)
// read parition 1 LBA from MBR
// LBA 4 bytes at address 0x01be offset 0x08
// Little Endian
part1_addr = (unsigned long)SDRdata[0x01C6];
part1_addr |= ((unsigned long)SDRdata[0x01C7]<<8);
part1_addr |= ((unsigned long)SDRdata[0x01C8]<<16);
part1_addr |= ((unsigned long)SDRdata[0x01C9]<<24);
// multiply LBA by sector size to
// get address of first sector of first partition
part1_addr *= 0x00000200;
// read first sector (PBR) of
// partition 1
SDcard_read_block(part1_addr);
// read out sector size in bytes
sector_size = SDRdata[0x000B];
sector_size |= SDRdata[0x000C]<<8;
// read out sectors per cluster
sectors_cluster = SDRdata[0x000D];
// read out number of reserved sectors
sectors_reserved = SDRdata[0x000E];
sectors_reserved |= SDRdata[0x000F]<<8;
// read out number of FATs
FAT_copies = SDRdata[0x0010];
// read out number of maximum root entries possible
root_entries = SDRdata[0x0011];
root_entries |= SDRdata[0x0012]<<8;
// read out single FAT size in sectors
sectors_FAT = SDRdata[0x0016];
sectors_FAT |= SDRdata[0x0017]<<8;
// calculate addresses of both FAT copies
FAT_address[0] = part1_addr + (sectors_reserved * sector_size);
FAT_address[1] = FAT_address[0] + ((unsigned long)sectors_FAT * (unsigned long)sector_size);
// calculate root directory table start address
rootdir_start = FAT_address[1] + ((unsigned long)sectors_FAT * (unsigned long)sector_size);
// calculate start address of data region
datareg_start = rootdir_start + ((unsigned long)root_entries * 32);
void file_create(const char* filename){
// read first sector of FAT1
SDcard_read_block(FAT_address[0]);
// find first unallocated cluster
uart_puts("Searching first unallocated cluster...");
for(cluster_number = 0; cluster_number < 0xFFFF; cluster_number++){
if( (SDRdata[cluster_number*2] == 0) && (SDRdata[(cluster_number*2)+1] == 0) ) break;
uart_puts("done!\n");
// allocate cluster in FAT
// copy read sector
for(unsigned int i = 0; i < 512; i++){
SDWdata[i] = SDRdata[i];
SDWdata[cluster_number*2] = 0xFF;
SDWdata[(cluster_number*2)+1] = 0xFF;
// write new FAT to both fat copies
SDcard_write_block(FAT_address[0]);
SDcard_write_block(FAT_address[1]);
// calculate address of first sector in cluster
start_sector_address = datareg_start + (((unsigned long)(cluster_number-2)) * (unsigned long)sectors_cluster * (unsigned long)sector_size);
current_sector = 0;
extern char *itoa(address_buffer, cluster_number, 10);
uart_puts("Cluster number: ");
uart_puts(address_buffer);
uart_putc('\n');
extern char *ltoa(address_buffer, start_sector_address, 16);
uart_puts("Sector 0 address: ");
uart_putc('\n');
// read first sector of root directory table
SDcard_read_block(rootdir_start);
// search first unallocated entry
uart_puts("Searching first unallocated root table entry...");
for(entry_addr = 0; entry_addr < 0x0200; entry_addr += 32){
if( (SDRdata[entry_addr] == 0xE5) || (SDRdata[entry_addr] == 0x00) ) break;
extern char *ltoa(address_buffer, entry_addr, 16);
uart_puts("Entry number: ");
uart_putc('\n');
// copy read table block to SDWdata
// create file with filename
unsigned char offset = 0;
while(*filename){
if(*filename != '.'){ // use '.' in filename as delimiter
SDWdata[entry_addr+offset] = *filename;
filename++;
offset++;
else{
filename++; // skip ''.' in filename
// add attribute byte
// archive flag set
SDWdata[entry_addr+0x0B] = 0x20;
// set reserved byte to 0
SDWdata[entry_addr+0x0C] = 0x00;
// set millisecond stamp
SDWdata[entry_addr+0x0D] = 0x00;
// set creation time
// time 12:00:00
SDWdata[entry_addr+0x0E] = 0x00;
SDWdata[entry_addr+0x0F] = 0x60;
// set creation data
// date January 1, 2000
SDWdata[entry_addr+0x10] = 0x21;
SDWdata[entry_addr+0x11] = 0x24;
// set last access date
SDWdata[entry_addr+0x12] = 0x21;
SDWdata[entry_addr+0x13] = 0x24;
// reserved for FAT32
SDWdata[entry_addr+0x14] = 0x00;
SDWdata[entry_addr+0x15] = 0x00;
// last write time
SDWdata[entry_addr+0x16] = 0x00;
SDWdata[entry_addr+0x17] = 0x60;
// last write date
SDWdata[entry_addr+0x18] = 0x21;
SDWdata[entry_addr+0x19] = 0x24;
// enter file starting cluster
SDWdata[entry_addr+0x1A] = cluster_number & 0xFF;
SDWdata[entry_addr+0x1B] = (cluster_number>>8) & 0xFF;
// set initial file size to 0 bytes
SDWdata[entry_addr+0x1C] = 0x00;
SDWdata[entry_addr+0x1D] = 0x00;
SDWdata[entry_addr+0x1E] = 0x00;
SDWdata[entry_addr+0x1F] = 0x00;
// write data block
SDcard_write_block(rootdir_start);
void sector_open(void){
// read sector of cluster
current_sector_address = start_sector_address + ((unsigned long)current_sector * (unsigned long)sector_size);
SDcard_read_block(current_sector_address);
extern char *ltoa(address_buffer, current_sector_address, 16);
uart_puts("Address of current sector: ");
uart_putc('\n');
// copy read sector to SDWdata
void sector_close(void){
// write sector to card
SDcard_write_block(current_sector_address);
void file_append(const char* string){
// offset from beginning of write
// (byte number)
while(*string){
if(byte_number < 512){
SDWdata[byte_number] = *string;
string++;
byte_number++;
// increase file length
file_length++;
else{
// save current sector
sector_close();
// reset byte counter
byte_number = 0;
// next sector is needed, load next sector
current_sector++;
sector_open();
void file_update_size(void){
extern char *ltoa(address_buffer, file_length, 16);
uart_puts("File size: ");
uart_putc('\n');
// set file size
SDWdata[entry_addr+0x1C] = file_length & 0xFF;
SDWdata[entry_addr+0x1D] = (file_length>>8) & 0xFF;
SDWdata[entry_addr+0x1E] = (file_length>>16) & 0xFF;
SDWdata[entry_addr+0x1F] = (file_length>>24) & 0xFF;
// write first sector of root directory table
C:
fatfs.c:122:55: error: expected identifier
fatfs.c:127:61: error: expected identifier
fatfs.c:142:51: error: expected identifier
fatfs.c:220:63: error: expected identifier
fatfs.c:267:52: error: expected identifier
5 errors generated.
Please Help.
