ITF To TLU+ error: no conductor layers are found in ITF_MIN
cxx216
HI,
I am a new hand of back_end in digital IC,work with astro(Synopsys).
Foundry has supply .map file and .nxtgrd.but I need TLU+.and I have tried to extract itf file from nxtgrd file by deleting the "$" from "TECHNOLOGY" to "end of itf file" in .nxtgrd file.But every time I proceed the "ITF To TLU+",astro will told me that
---------Sanity Check on TLU+ Inputs-------------
Error:No CONDUCTOR layers are found in ITF_MIN
How do I solve this problem?
map tech itf
Dear Sir,
Do you use itf directly to load in Astro ?
You need to use grdgenxo command in Star-rcxt with itf file and generate TLU+ model.
Best Regards,
chyau
tlu+ and itf technology file
use itf to generate tlu and then load in astro
