iterate a 2d array in a circular manner
kidi3
Full Member level 1
Full Member level 1
Is it even possible and if so then how?
how do i iterate a 2d array such that at each angle degree I output one strip, located on that angle showed.. ex.
for 0 degrees will # be outputted.
 __  __ __ __ __
|__|__|__|__|__|
|__|__|__|__|__|
|__|__|__|__|__|
and so on for different different degrees.. the question, is how do compute the array position for the different angles.. for example for 45 degrees and so on..
use trigonometry and cast floats to ints?
Reactions: kidi3
    kidi3
well.. the problem is how?
I quite sure that the math is simple, but can't get my head around it..
