ilkinsan
Newbie level 1
matlab pc cam
Hi All,
I have been studying on web cam application.
1)In the "main.m", I used setappdata(handles.himage,'UpdatePreviewWindowFcn',@ Processingeyedetection);...
2)In the "Processingeyedetection.m", I used:
function ProcessLeft(obj,event,himage)
%save the image into the temp to call again at the end of the program
temp=event.Data;
%PLACE-A
event.Data=temp;
%turn back into the main program
set(himage, 'CData', event.Data);
Result: It works fine,if there is no script PLACE-A. If there is scripts, the camera view becomes very slow. When I hands up, I show it after 14-15 seconds. (Meanwhile, the used RAM becomes close to around 100Mb.) When I disable PLACE-A, the program works normal, and show the memorized frames very fastly, then turn in normal speed. You can say that PLACE-A has a big computational load.
BUT!
I measured the processing time of PLACE-A, it is only 0.2 seconds. But, why I see that frame after 14-15 seconds. Is the problem in the main function? If it is about "main.m", why I don't have any trouble when there is no script in PLACE-A?
Thank you.
Best regards,
Hi All,
temp=event.Data;
%PLACE-A
event.Data=temp;
BUT!
Thank you.
Best regards,
