aliyesami
Full Member level 6
i made a 4X15w UV exposure unit using GE F15T8-BL . my pcb sits 2 inches above the bulbs . I cant seem to get the thin track lines. I even tried low exposure times of just 4 mins but the ground area came out good but the thin lines didnt get developed.
I am not sure i am exposing it right . i use continous exposure but i was reading online that you have to give bursts of exposure .can some one explain how?
also i made the print out on inkjet transparency. should i put the coarse face (Where the ink print is ) on the glass or the other side?
I also noticed that the sensitized pcb are sticky once i remove the protective cover. should i press the tranparency against the pcb so it snugs around the pcb tight ?
what are the best practices in this pcb making area if someone can guide me.
thanks
thanks
