Issue in PIC18F2553 USB
embdev4
Newbie level 1
Newbie level 1
I’m using PIC18F2553 for the ADC recording purpose. What I want to do is, get a few ADC values of different channels into a buffer and then send it to Computer through USB in CDC mode. I’m taking ADC values at an interval of 8KHz(125usec) with help of Timer0. The Timer Interrupt is set at Low Priority and the USB Interrupt at High Priority.
I’m using 2 buffers of 256B each. At start first buffer fills up, and when filled up, sent to USB. In the meantime, the second buffer starts filling up, and when filled up, it is sent to USB. So, the process continues.
But the issue, I’m struck in is that I do not receive any data on Terminal when the Timer is run at this speed. Although it gets enumerated and I can open the port also, do not receive anything. When I run Timer at Low Speed, I start getting both the buffers alternatively (as desired).
So what could be the solution out to this issue because I don’t think that USB does not get enough time to send its data as one buffer is sent after an interval of 30*125usec.
CODE:
void YourLowPriorityISRCode()
		//Check which interrupt flag caused the interrupt.
		//Service the interrupt
		//Clear the interrupt flag
		//Etc.
	            if(INTCONbits.TMR0IF == 1)        //Timer0 ISR
                    INTCONbits.TMR0IF = 0;
//					adc_calculation();
//					adc_calculation_one_ch();
					new_adc_calculation();
					TMR0H=0XFD;
					TMR0L=0X8F;
	}	//This return will be a "retfie", since this is in a #pragma interruptlow section
int main(void)
    InitializeSystem();
	TRISA = 0xFF;
	TRISB = 0xFF;
	memset(adc_buff,0x00,256);
	memset(adc_buff_2,0x00,256);
	ADCON1=0x00;
	ADCON2 = 0xB5;
        ADCON0bits.ADON = 1;           // Turn on ADC module
                       // internal Vref=4.53V
   #if defined(USB_INTERRUPT)
       if(USB_BUS_SENSE && (USBGetDeviceState() == DETACHED_STATE))
           USBDeviceAttach();
   #endif
     while(USBGetDeviceState() != CONFIGURED_STATE);
     UserInit();
    while(1)
	    if(buffers_full_F==1)
		   send_adc1();
		   buffers_full_F=0;
		   clear_adc_buffers();
    }//end while
}//end main
static void InitializeSystem(void)
    #if defined(USE_USB_BUS_SENSE_IO)
    tris_usb_bus_sense = INPUT_PIN; // See HardwareProfile.h
    #endif
    #if defined(USE_SELF_POWER_SENSE_IO)
    tris_self_power = INPUT_PIN;	// See HardwareProfile.h
    #endif
    USBDeviceInit();	//usb_device.c.  Initializes USB module SFRs and firmware
    					//variables to known states.
}//end InitializeSystem
void UserInit(void)
   RCONbits.IPEN=1;	  //enable priorities
   INTCON2=0x00 ;   //low priority to timer0
   T0CON=0x08;
   TMR0H=0X00;
   TMR0L=0X00;
   INTCONbits.TMR0IE = 1; //Enable Timer0 Interrupt
   T0CONbits.TMR0ON=1;  //Start Timer
}//end UserInit
void send_adc1(void)
    // User Application USB tasks
    if((USBDeviceState < CONFIGURED_STATE)||(USBSuspendControl==1)) return;
	if(USBUSARTIsTxTrfReady())
		if(buff_sent_F==1)
	       	       putUSBUSART(adc_buff,250);
		else
			putUSBUSART(adc_buff_2,250);
        while(cdc_trf_state != CDC_TX_READY)
    		CDCTxService();
void new_adc_calculation(void)
	char i=0, *ptr;
	float adc;
    unsigned int ADC_data=0;
	tick++;
	//start channel 4 adc
    ADCON0bits.CHS0 = 0;          // Select ADC channel
	ADCON0bits.CHS1 = 0;          // Select ADC channel
    ADCON0bits.CHS2 = 1;          // Select ADC channel
	ADCON0bits.CHS3 = 0;          // Select ADC channel
//	for (i=0; i<50; i++){i=i;}     // aquisition delay
	ADCON0bits.GO_DONE = 1;           // GO
	while (ADCON0bits.GO_DONE){i=i;}	// wait until conversion is complete
	ADC_data = ADRESL + ( ADRESH * 256)	;		// Read ADC register
	adc=(ADC_data * Vdd/4096);
    ptr=(char*)&ADC_data;
   if(buff_sent_F==0)
	   	adc_buff[2+2*(tick-1)]=*ptr++;
	   	adc_buff[3+2*(tick-1)]=*ptr;
   else
	   	adc_buff_2[2+2*(tick-1)]=*ptr++;
	   	adc_buff_2[3+2*(tick-1)]=*ptr;
	//start channel 8 adc
    ADCON0bits.CHS2 = 0;          // Select ADC channel
	ADCON0bits.CHS3 = 1;          // Select ADC channel
	adc=(ADC_data * Vdd/4096);         //CHANGE VDD as per our requirement
    if(buff_sent_F==0)
   		adc_buff[63+2*(tick-1)]=*ptr++;
   		adc_buff[64+2*(tick-1)]=*ptr;
	else
   		adc_buff_2[63+2*(tick-1)]=*ptr++;
   		adc_buff_2[64+2*(tick-1)]=*ptr;
	//start channel 9 adc
    ADCON0bits.CHS0 = 1;          // Select ADC channel
    if(buff_sent_F==0)
    	adc_buff[124+2*(tick-1)]=*ptr++;
    	adc_buff[125+2*(tick-1)]=*ptr;
	else
		adc_buff_2[124+2*(tick-1)]=*ptr++;
    	adc_buff_2[125+2*(tick-1)]=*ptr;
	//start channel 10 adc
	ADCON0bits.CHS1 = 1;          // Select ADC channel
    if(buff_sent_F==0)
	    adc_buff[185+2*(tick-1)]=*ptr++;
	    adc_buff[186+2*(tick-1)]=*ptr;
	else
	    adc_buff_2[185+2*(tick-1)]=*ptr++;
	    adc_buff_2[186+2*(tick-1)]=*ptr;
	if(tick==30)
	    if(buff_sent_F==0)
			adc_buff[0]='S';
			adc_buff[1]='T';
			adc_buff[62]='@';
			adc_buff[123]='@';
			adc_buff[184]='@';
			strcpypgm2ram(&adc_buff[245],(const rom far char *)"END\n\n");
		else
			adc_buff_2[0]='M';
			adc_buff_2[1]='M';
			adc_buff_2[62]='@';
			adc_buff_2[123]='@';
			adc_buff_2[184]='@';
			strcpypgm2ram(&adc_buff_2[245],(const rom far char *)"END\n\n");
		buff_sent_F=!buff_sent_F;
		tick=0;
		buffers_full_F=1;
void clear_adc_buffers(void)
    if(buff_sent_F==1)
	else
void packet_TX(char HB,char LB)
int res=0,temp,k;
int arr[4];
// Calculate Decimal Value of {HB,LB}
for (k=1;k<=128;k=k*2)
temp = LB;
temp = temp & k;
res += temp;
for (k=1;k<=2;k=k*2)
temp = HB;
temp = temp & k;
temp = temp * 256;
res += temp;
k = 0;
if (res==0)
for (k=0;k<4;k++)
brr[k]='0';
else
while(res!=0)
arr[k] = res%10;
brr[k] = arr[k]+48;
res = res/10;
k++;
flag = 1;
count = k-1;
TXREG = brr[count];
PIE1bits.TXIE=1;
plz tell me the algo of this cod
