Isolation in strip line couplers
chandregowda
Full Member level 4
Bengaluru/Bangalore, India
hi,
i have done wideband 15dB coupler upto 6GHz. the isolation S(1,4) is increasing curve from -37.83dB (@700MHz) to -20.5dB (@ 6GHz), the coupler was designed for 700-6000 MHz bandwidth. The other parameters return loss -24dB Min, insertion loss-0.6dB Max, coupling -15dB, flatness (± 0.8dB) of the coupler are ok.
how can we improve the isolation? if i calculate the directivity (isolation - Coupling) at 6GHz it will be 0dB or -0.5dB, is that oK?
coupler is Strip line based design.
hi,
Flatness is 15±0.8dB in the overall frequency range from 700-6000MHz.
Directivity is 5dB @ 6000MHz not 0 dB, it was mistake that i have taken.
but a min of 10dB directivity is desirable, how do i improve that?
The design is Strip line edge coupling method.
It's better to show your circuits.
Try to make the grounding better,especially the upper board.
hi,
it is basically Stripline technology with Edge coupling method
multi sections are used to get the broadband operation, sections are asymmetric.
width, W and separation between each section are calculated by even and odd mode impedances. W, S are optimized to get the proper coupling and other parameters.
but Isolation not met the specification, after varying these parameters.
Hello,
Can you please guide me on how to get the values for w and s for every section of the coupler?? Are there any calculators available for these?
