Electro nS
Full Member level 6
i am facing some problems between 2 micros communicating in TTL serial. for some reason the serial module is burning on both sides .
is there is a way to use some kind of isolation (optocouplers or IC) to prevent a failure or short on one side from burning the serial module on the second side .
i have searched a bit , i found that an easy way might be to use RS485 converter from Maxim , but it contains only buffers inside to get differnial output and i donot know if it can provide the necessary protection , also considering max232 on both side which could help reducing noise !
any ideas ?
thanks in advance
any ideas ?
thanks in advance
