wizpic
Advanced Member level 3
I have a project where I need to measure 4 x 24v battery banks which are isolated from each other. I really only want to use 1 Arduino to record the data onto single SD card. I've used an ADS1115 (18 bit converter) to read the voltages at the moment I'm using a dual power supply reading the 4 channels with common ground but I can't have a common GND has this would cause issues. I've looked at galvanic isolation but they seem to use transformer and other components and the more I looked the more confusing it's causing and not sure if it would have an effect on the readings or cause un-stable readings. The code is all working well and had it on soak test for nearly a week to make sure there are no issues or bugs but it's time to go for isolation method.
Which would be the best approach any idears or input would be grateful.
Thanks
Wizpic
Thanks
Wizpic
