Isolated or Metal Bushing Jacks with NO or NC switching
danny davis
Banned
Advanced Member level 2
Hollywood
How do you know from looking at the schematic if this jack is Isolated plastic bushing or uses a Metal Bushing?
How do you know if the Switching is NO or NC switching?
What is the name of this jack? it's a Tip Ring Sleeve but It has a 3 switch on the jacks ground
They Call it a Remote switch Breakaway
https://www.google.com/search?q=pea...mfforum%2Findex.php%3Ftopic%3D89576.0;491;333
Here is another picture:
https://www.google.com/search?q=peavey+valveking+212+schematic&espv=210&es_sm=93&tbm=isch&tbo=u&source=univ&sa=X&ei=mOejUoifCITooATo3oHoBg&ved=0CCwQsAQ&biw=763&bih=466#es_sm=93&espv=210&q=peavey+valveking+schematic&tbm=isch&facrc=_&imgdii=g96kIHOaMONlhM%3A%3B2Qlbe4e-X9BbHM%3Bg96kIHOaMONlhM%3A&imgrc=g96kIHOaMONlhM%3A%3BHZ2wTf6h4_-xjM%3Bhttp%253A%252F%252Fi.imgur.com%252Fvapx6.gif%3Bhttp%253A%252F%252Fwww.diystompboxes.com%252Fsmfforum%252Findex.php%253Ftopic%253D89576.0%3B491%3B333
https://www.google.com/search?q=peavey+valveking+212+schematic&espv=210&es_sm=93&tbm=isch&tbo=u&source=univ&sa=X&ei=mOejUoifCITooATo3oHoBg&ved=0CCwQsAQ&biw=763&bih=466#es_sm=93&espv=210&q=peavey+valveking+remote+switch+breakaway&tbm=isch&facrc=_&imgdii=g96kIHOaMONlhM%3A%3B2Qlbe4e-X9BbHM%3Bg96kIHOaMONlhM%3A&imgrc=g96kIHOaMONlhM%3A%3BHZ2wTf6h4_-xjM%3Bhttp%253A%252F%252Fi.imgur.com%252Fvapx6.gif%3Bhttp%253A%252F%252Fwww.diystompboxes.com%252Fsmfforum%252Findex.php%253Ftopic%253D89576.0%3B491%3B333
You can safely assume that it's a standard isolated & switched 1/4" stereo jack like Cliff CL1220A https://www.cliffuk.co.uk/products/jacksockets/s2.htm
The isolation point is obvious from the existence of the 10 ohms ground series resistor.
P.S.: NO or NC can be well read from the schematic, you need to read however,
What is this 10ohm ground series resistor used for? ground loops? but how is it working?
Why would they have a Switch inside the jack to have the isolation point NO when a plug was inserted into the jack?
What's the point of having an isolation switch inside the jack?
What are these jacks called?
What is jack C called?
Jack B is a Tip and Ring
Jack D is a Tip , Ring, Sleeve, With NC switches?
What is Jack C called?
Tip Shunt, Ring Shunt, Sleeve Shunt
Some jacks shunts are either NC or NO
Why do they use a Sleeve Shunt also? for the REMOTE BREAKAWAY SWITCH?
What is this jacks name called?
Where do you find these Jack schematics ? so I can look them up to know what the names of them are and to order the right one?
There is so many that are Tip, Ring , Sleeve, Some are NO or NC, some have Tip shunts, Ring shunts, Sleeve shunts
But where do you find the jack schematics to see which jack is the right one?
some jacks have a "Transfer Switching" I need the jack schematic for this
some jacks have a "Isolated Switching" I need the jack schematic for this
What is the Transfer switching used for?
What is the Isolated Switching used for?
I just found the Jack Schematics , do you guys know any others please
http://www.surplussales.com/Connectors/pdf/Jack-Schematics.pdf
It's hard for me to tell the difference between a SHUNT switch , Transfer switch, Isolated switch
They all look the same to me
do you know the name of this jack? it has a Sleeve shunt
https://www.google.com/search?q=peav....0%3B491%3B333
Or why it has a Sleeve Shunt? I don't see these much with a Shunt on the Sleeve
A plus in this jack will NO the shunt, why ?
