isolated DC to DC converter for -5.2V
ballimo
Member level 3
Member level 3
dc to dc converter
Hello All,
I am using a optical module that required 5, 3.3 and -5.2V. the current needed at the -5.2 V rail is 4A, I was searching a -5.2V non-isolated DC to DC converter with an output current up to 4A I did not find any because the input voltage to this non-isolated DC to DC converter is 5V (the board have only a single 5 V supply).
I am planning to use an isolated DC to DC converter for the -5.2V, but I don't know how to design this circuit, the only thing I know is to connect the positive to GND.
can anyone help me with this design? if I use this isolated converter the ground of the -5.2V will be different from the module ground (5V, 3.3V...) does this work?
did anyone have some material about this issue?
Thanks,
Ballimo
