I guess capacitive coupled differential digital coded transmission with zero dc format like +- pulse sequence.
The critical point is have a voltage rise time greater than the maximum common mode voltage or isolation voltage rise or fall time. That is typical specified with a isolation voltage derating at higher isolation voltage frequencies.
