isDir problem(Assura 3.1,IC5033,Fedora Core 2)!Please help!
vlado
Newbie level 3
Newbie level 3
should be either a string or a symbol
Hi!
I have installed IC5033 and Assura 3.1 on Fedora Core 2. Unfortunatelly I cant start Assura RCX! When i try to start Assura RCX from Virtuoso, a folowing error is reported:
"*Error* isDir: argument #1 should be either a string or a symbol (type template = "Sg") - nil"?
Please help!
Thanks,
Vlado
P.S. Assura DRC and LVS works!
assura drc .cdsinit setting
This is .cdsenv problem. Find it and correct by aid of "Cadence environment variables and configuration help" .It's not very difficult.
assura,cdsinit
I have installed IC 5.0.33 USR1 and ASSURA 3.1.2 on Red Hat Linux 7.3 and I have the same problem when i try to start Assura RCX from Virtuoso:
On Solaris 8 run whitout problems
I have looked the .cdsenv and .cdsinit and i am sure that these files are correctly written...
Please, help me!...
assura libavview
I have installed IC5033 and assura 3.1 . I can invoke assura alone by
avview &
but I can not invoke assura in dfII .In the CIW window :
there is a warning :
cann't load libavview.so .
And I want to declare that I am the owner of this file .
could you give me some suggestion ?
Thanks a lot .
isdir linux
Are you sure that your Assura support the Linux platform?
assura cd linux
yes ,I am sure .
