[SOLVED] ISCAS combinational circuits required.
dhaval4987
Full Member level 3
AZ
Hey all,
I specifically need combinational circuits verilog descriptions by ISCAS. All I find are sequential. Can anyone provide combinational circuits?
actually you dont
there are no library instances, all cells declared exist within verilog itself. read a verilog reference.
No, the functional description of gates is not declared in the verilog file for which i am looking for.
I think i will have to write it then.
gosh...
the functional description is the verilog language! find a good book and you will find out what the nand, buf, or, etc. means.
---------- Post added at 16:34 ---------- Previous post was at 16:29 ----------
search for verilog primitives and you will understand what i am talking about.
No snp, I think you misunderstood.
I know what XOR/And/Or is. But what I want to do is that I want to perform of static timing analysis of ISCAS85 benchmark circuits. And the timing tool nanotime does not understand the fucntions of these gates. to make it understand- I need those models. If not that- then I need Spice level descriptions of these combinational circuits.
you cant perform sta on those circuits because they havent been synthesized yet. those are not standard cells, those are verilog primitives.
