is this SNR/DR spec reasonable??
xuedashun
Member level 1
Member level 1
In a class D amplifier,, 2 stage sigma delta modulator + driver + speaker
the input is analog signal
the spec is: SNR/DR min=85dB, -60dBFS
From my understanding, it's impossible for 2stage SDM to reach 80dB SNR
so if the SMD is used in classD, is the 85dB spec reasonable?, if reasonable,
why??
Thanks.
I think the specs are reasonable.
It's not true that you can't achieve more than 80dB in 2nd order sigma-delta modulator. You can achieve it depending on the OSR selected by you.
