mamech
Full Member level 3
Hello
I have found this datasheet for a bridge rectifier :
https://www.ram-e-shop.com/ds/general/KBP307_Bridge.pdf
In the beginning I intended to use it instead of building the rectifier circuit, but after I had a look over the the datasheet, I really got confused.
It is written in datasheet something about half wave.(does this mean it is half wave rectifier ?then how it produces pure DC ?)
Also I thought that it may have internal capacitor to reduce ripple.
Another weird thing, that I have read in the beginning of datasheet:
"Voltage range 50 to 1000 volts"
Why does it have a minimum range? I was intending to use it to rectify an AC 6 volts. Does this mean that it will not work?
Thanks
Thanks
