Is there anybody who had ever taped out chip which size was larger than 3cm*1cm?
nksunmoon
Junior Member level 2
Is there anybody who had ever taped out chip which size was larger than 3cm*1cm? I don't know is there any restriction to tape out so large chip.Is there anyone who has the experience?
I haven't done one that large but have spoken to a fab about it for one project I was doing. There is some limit to do with the mask sizes I think, but they can go above that limit with some technique ("stitching"?). The result is a more expensive mask set (I am not sure if it needed two full mask sets) and more expensive processing. It is probably best to speak to the fab.
Keith.
Camera producers have: 50MP (Mega Pixel) CMOS sensor chips are 49mm*37mm, see here. Hubble space camera chips are said to be even larger.
I also have heard that there is some restrictions when prducing the mask.Thank you for your advice
I also have heard that there is some restrictions when producing the mask.
Right. The max. chip size for a single mask set depends on the process lithography (I remember 15mm*15mm for a 180nm process). For larger chips "mask stitching" is needed as Keith mentioned above. This of course is a special and rather expensive service, as 2 or more mask sets and additionally very special lithography steps are needed (the overlapping area of 2 adjacent masks must receive an adapted light blocking pattern, see e.g. this patent).
Erikl,
Thanks for the clarification. The chip I was looking at a while ago was 0.8um and the limit was around 25mm I think and we needed 30mm. The cost jumped and pretty much killed the project.
Keith
Re: The cost jumped and pretty much killed the project.
... we needed 30mm. The cost jumped and pretty much killed the project.
I guess! :-( Couldn't you try and use a tighter process?
I should have mentioned it had a photodiode array on chip and we had to produce a certain optical size - hence the length.
Keith
I have taped out sensor 6cm by 6cm Silicon strip detector , my foundary supports contact mask . In your case find the reticule size the fab is using , it is usually 30mm by 30 mm, but this doesnot mean that you cannot beyound it, A mask stiching process is done for designs higher than reticule size. The yeild would not cross 70%
You must have a big pocket book. Look up Poisson distribution for yield on such a large chip.
You should average about 5 to 7 good parts out of a 300 mm wafer, in range of about $400 per I.C. (not countng mask charges)
yeah, Maybe I should contact to the fab and ask how much the chip will cost
Its Sensor , with six mask process. these are already in place at CMS-CERN experiment.
