is there any alternate for this part STR-Z2757 ?
Alwaleed2
Member level 3
Member level 3
str-z2757
In a HP 1100 printer this part is damaged ? is there any alternate for it ? is there any function do its function ?
str z2757
I believe this is a power supply IC of some type from the Japanese manufacturer Sanken. Look here at their web page **broken link removed**
I have not been able to locate this part on their website because it is probably an OEM part made for HP with special number. I do see sites that claim to have the datasheet but it seems that it costs money to get the datasheet. Can you be a little more specific about how many pins the IC has and what is around it. This may give some more clues about what this part really is and what you may be able to replace it with.
Then Sanken website list the following items (with datasheets) -- some of them being obsolete.
No. Product Category Part Nubmer or Model Information Notes
SMPS Power IC STR-A6131
SMPS Power IC STR-A6132
SMPS Power IC STR-A6151
SMPS Power IC STR-A6153E
SMPS Power IC STR-A6159
SMPS Power IC STR-A6169
7
Switching IC for compact power supply STR-A6251
8
Switching IC for compact power supply STR-A6251M
9
Switching IC for compact power supply STR-A6252
10
Power IC for fluorescent lamp inverters STR-B5454
Contact Our Office
11
Integrated Power System IC for PFC/DC-DC Control STR-E1565
12
Switching Regulator IC STR20005
Discontinued Product
Substitute:SI-8050S
13
Switching Regulator IC STR2005
14
Switching Regulator IC STR2012
15
Switching Regulator IC STR2013
16
Switching Regulator IC STR2015
17
Switching Regulator IC STR2024
18
Power Stage IC For Switching Regulator STR7001
19
Power Stage IC For Switching Regulator STR7002
20
Power Stage IC For Switching Regulator STR7003
21
Power Stage IC For Switching Regulator STR7101
22
Power Stage IC For Switching Regulator STR7102
23
Power Stage IC For Switching Regulator STR7103
24
Voltage Doubler/Bridge Rectifier Automatic Switch IC STR80145A
25
Voltage Doubler/Bridge Rectifier Automatic Switch IC STR81145A
26
Voltage Doubler/Bridge Rectifier Automatic Switch IC STR81159A
27
Voltage Doubler/Bridge Rectifier Automatic Switch IC STR82145
28
Voltage Doubler/Bridge Rectifier Automatic Switch IC STR83145
29
Voltage Doubler/Bridge Rectifier Automatic Switch IC STR83159
30
Linear Regulator IC STR9005
31
Linear Regulator IC STR9012
32
Linear Regulator IC STR9015
Best regards,
v_c
