Is there a way to take an entire component off of the tCream layer?
blankk
Newbie level 5
Newbie level 5
I don't want to modify the library part if possible - is there another way?
is it possible .. to get a detailed descripion of what you want to know?
What are you talking about?
Software?
Pictures?
Library?
"Life is valued treasure time" This isn´t only true for you, it is true for us, too. Therefore: Stick to it.
Klaus
Hi
Sorry for lacking of detailed info
I'm talking about the Eagle software, because of the tCream layer, so I didn't mentioned the software name.
Is there a way needn't to create a new component without that layer, based on the old component?
TCream is automatically generated from the SMD pads.
You don't even have to add it in the library. And I don't know how to avoid it, maybe by drawing a rectangle in the Top layer and the same rectangle at the tStop layer.
What's the problem with the tCream? Why do you want to avoid it?
Klaus
You can make a copy of the package and replace the pads by a pad definition with disabled solderpaste.
That's possibly with any full featured layout tool. According to user manual, it should work with Eagle, too.
Reactions: blankk
    blankk
I agree .. that´s the easy way ;-)
It´s the way to go.
Btw:
Copying the device from the original librrary to YOUR library is very easy.
* Open YOUR library
* goto the control panel window.
* select the original library
* RIGHT mouse click to select the device of interest - select "copy into library" (= YOUR library, because it is still open in the library window)
* then modify the package in YOUR library.
* to include th new device in the board:
* you can either delete the old one and add a new one, then you have to rout all the air wires.
* or you can use "replace" instruction: slect YOUR library, select the modified device, click on the original device in the board window. (tOrigins must be enabled)
Klaus
Reactions: blankk
    blankk
