Is there a unix equivalent dos2unix utility in linux?
shemo
Full Member level 1
dos2unix sed
I couldn't find it. pls advise.
thanks
vi dos2unix
just remove all "^M" from your files using vi or sed or other editors. no need using dos2unix, you can write a simple script to implement this. and name dos2linux. :)
sed dos2unix
Hi, There:
dos2unix linux
Hi
Try this perl script
#!/usr/bin/perl
# convert a dos \r\n format to unix \bn
open (FILE, $ARGV[0]);
while (<FILE>) {
# remove the stupid \r, replace with \n
# some broken editors just put \r
s/\r/\n/g;
# Remove the duplicate \n
s/\n\n/\n/g;
print;
tnx
linux dos2unix
Hi
BTW:
Look at the following perl link for additional free perl scripts.
It is searchable too.
1. h**p://www.perlmonks.org
* -> t
tnx
dos2unix on linux
Or you meant the reverse operation: unix2dos.....
