This can't be correct. Think of of the automatic clock gating that is inserted by power compiler or RTL Compiler. You don't generated clocks added for those.yaa..main reason behind specifying generated clocks is, "by default CTS will not balance skew for exclude pins..so if we not specify the generated clocks, then tools treats that as exclude pin, and will not try to balance the skew"
