whack
Member level 5
Hey all,
I need a multiplexer for my project that will hold output until a next control pin event when it will latch a new value. Basically a multiplexer with a built-in latch or flip-flop.
So the pins should be input 1, input 2, output, select, latch/gate/clock. For example the latch control can be connected to a clock signal to hold a new value on clock edge.
I understand that I can add a latch or flip-flop after a multiplexer but I was wondering if there's a one chip solution for this.
Could someone show me an example of an off-the-shelf part and recommend one for my project? I need two multiplex two 12-bit (or 16-bit) data inputs.
