T
treez
Hello,
We are using LEDs in parallel in our product, so we need the LEDs to be from the same voltage bin.
We are using the Osram Power TOPLED "LA E67F"
Is the voltage bin code marked onto the actual LED itself?, or is the bin code only on the reel or tape in which the LED is delivered?
Power TOPLED datasheet:
Do you know of any LED brands which have the voltage bin code marked onto the actual LED package?
We need it to be marked on the package so that we can check that the PCB assemblers are using LEDs from the same voltage bin.
