Is the S21 plot result given in the voltage ratio or the power ratio in ADS Momentum?
raebrm
Junior Member level 2
Just a simple question. Is the S21 plot result we get from momentum in dB the voltage ratio or the power ratio? Is there a method to convert one to another in ADS?
Thanks!
S21 in ADS Momentum
S-Parameters are voltage ratios
    raebrm
Re: S21 in ADS Momentum
S parameters are actually power-wave ratios [W]^1/2. You cannot assume that all you reference port impedances are the same. I know, I know, we all are working with Z0i=50 but I'm a little academy biased :)
    raebrm
To see the power of a certain node in your circuit you must give a name at the node, run the simulation and than from datadisplay you can write the expression dbm(nodename) than you can also plot this
see also
www.uwaverf.altervista.org/forum
    raebrm
thanks for the replies. I did some tests on ADS and i think that S21 gives the voltage ratio when we display the S21 in terms of its magnitude (V0/V1). But if we display the S21 in terms of dB, it's converted into 20*log(V0/V1), so the plot in dB is the same for power or voltage, since the power in dB is 10*log(P0/P1) and P0=V^2.
hope i didnt have a huge misconception here.
thanks!
Yes, this is correct.
Chinaski mentioned the special case where you have mixed reference impedances, and then it gets a little bit more complex. But for the normal case with identical reference impedance on all ports, your description is correct.
    raebrm
wonderful! thanks so very much
