is the postive voltage to PN junction that allow the current to pass through it?
TicTek
Junior Member level 1
Hi folks,
I was led to confusion by an experienced electronic engineer who told me that for a diode (PN Junction), it is not only that if apply a voltage across its terminal that will make it conduct but also if we force a current into it, it will generate a differential voltage on its terminal!!
So, here I am confused of cause/effect. Is the voltage that causes the current, or also a forced current causes a voltage?
All books I read they specify applied voltage leads to a diode conducting current!!
'Forcing' current doesn't sound right, it will conduct a current when sufficient voltage is applied across the terminals. I think the confusion may be that when a PN junction is conducting (passing a current), there will be a voltage dropped across it, much as there would be if a current passed through a resistor. Different junction materials and particular device types may result in different voltages but unlike a resistor, the voltage stays relatively constant as the current changes.
Brian.
there are (constant) voltage sources ... and (constant) current sources.
Both feed the "value" to a load.
For a (constant) voltage source ... no load is needed. The voltage exists and can be measured and regulated.
This is different with a current source. It needs a load for a current to flow.
Indeed a constant current source usually regulates the voltage in a way that the expected current will flow.
Now what your electronics engineer means (most probably):
You can apply a constant current to a PN ... and then you can measure a voltage across the PN.
But for sure - as said above - it needs a voltage for a current to flow.
For sure one can bring up extreme examples where this seems not to be true.
Like a ring of supra conductor ... when an external magnetic field is applied.
There surely will be current flow within the supra conductor ... but is there also a voltage, too?
Klaus
LaTeX Commands Quick-Menu:
