SINDHURI
Member level 2
Tahmid Sir Thanks for Your kind information regarding the dimmer triac module
The the normal operation of the module is that if we are giving 66% as the input command the module then it gives output operating the device as 33%. If we give inverse input to the module is it operate correctly or not. That means if the input command is 66% then the output that operating the device also 66%.
Thanks in Advance.
Thanks in Advance.
