powersys
Advanced Member level 1
Pls look at the Load Impedance calculation. The answer is given in the shaded (gray) box. Is the answer CORRECT? If YES, pls advise how to get it. The answer I got is ZL = 3.26 + j2.02. Pls advise. Thanks.
Did u mean the answer for ZL in gray is CORRECT?jeffttan said:The answer in gray is correct. can you post your solution so that we can see what the difference is? or what is wrong..
thanks
In your answer, it's 3.26 - j2.02. Why not 3.26 + j2.02? Thanks.smxx said:hi
you are ok
