swen_s
Member level 1
Is it safe to route through a SMD pad or should I always make a T connection to the pad?
And when is it safe to connect SMD pads withoud thermel thermal reliefs? Is it ok for 0805 but not for smaller packages? I often see evaluation boards for DC/DC converters that connects decoupling capacitors from a ground plane to a copper area without any thermal reliefs.
