Sunny55
Full Member level 3
I m using a car battery to run 2 usb chargers. There is a switching regulator circuit in between the battery n chargers to step dwn 12vdc to 5vdc and the 5vdc to power usb charger. That should be SAFE with such configuration ?
Is the switching regulator circuit sufficient to provide protection to the chargers or do i need fuse for protection or someother circuits? Pls help.
