eltonjohn
I want to have a better idea of the power requirments for most of the mid range FPGA ( spartan 3 and others like) i discovered this documents : comming from Ti **broken link removed** .
Now has any body used FPGAs for portable solutions here?.. how can i manage the power to keep it as low as possible .. I know from all times that the power consumption on a FPGA is proportional to the number of gates switching at the same time .. Basically can a portable SoC type of solution can be implemented on any type of FPGA or are ther some to avoid ..
i look at the VIRTEX II pro .. this chips as small as they, are can take as much as 10 Amps at 1.5 V !!!!!!!!!!!
So out the question to put them on a satellite !
so any documents that you can advice??
