Is it possible to use IR2113 as a "Half Bridge Driver&q
fixxxer_ki
Newbie level 1
Newbie level 1
IR2113 is an IC which is designed to be a "high and low side driver" it has two different leads that go toward a load. While in "Half Bridge Driver", for example IR2111, We just have a lead that goes toward our load. Moreover, in IR2111, the Vs lead and source of MOSFET1 and Drain of MOSFET2 is connected together and all of them connects to the starting point of the load. So How can I use IR2113 to get IR2111 Half Bridge circuit?
Thanks in advance.
IR2111 Datasheet:
http://www.irf.com/product-info/datasheets/data/ir2111.pdf
IR2113 Datasheet:
http://www.irf.com/product-info/datasheets/data/ir2110.pdf
