Marios91
Junior Member level 3
Hello,
I have designed a rather small rf ciruit and the long sma ground pins are causing problems because they are falling int the circuit and i can't make longer transmition lines as they are causing problems in the simulation.Is it possible to shorten the sma's ground pins to fit my pcb properly or there will be problems?
Thanks in advance
Thanks in advance
