Aug 17, 2006 #1 E evl_inside Member level 2 Joined Aug 10, 2006 Messages 50 Helped 4 Reputation 8 Reaction score 1 Trophy points 1,288 Location Mars Activity points 1,555 Drill Pattern Hello, Is it possible to make Oval drill Patterns in Protel DXP. If yes then how?
Aug 17, 2006 #2 C centiago Full Member level 3 Joined Sep 30, 2005 Messages 173 Helped 16 Reputation 32 Reaction score 2 Trophy points 1,298 Location Lions Den Activity points 2,684 Re: Drill Pattern Yes you can. There are two ways. 1> Crude/Primitive method .... Keep adding The required hole sise overlapping each other. It works fine. 2> Create a slot . Refer to the fig attached. make sure you specify the XY location of slot WRT Origin. Hope it helps. Centiago
Aug 18, 2006 #3 E evl_inside Member level 2 Joined Aug 10, 2006 Messages 50 Helped 4 Reputation 8 Reaction score 1 Trophy points 1,288 Location Mars Activity points 1,555 Re: Drill Pattern Thanks for the Help. Can you also suggest me where and how can I specify the XY Location of the Drill. Is it to be done in the Gerber Data? Devil.
Aug 18, 2006 #4 C centiago Full Member level 3 Joined Sep 30, 2005 Messages 173 Helped 16 Reputation 32 Reaction score 2 Trophy points 1,298 Location Lions Den Activity points 2,684 Re: Drill Pattern Just give X & Y location of center of semi circle one of the semicircle. Then specify the length of slot. Reffer to the pic I attached earlier. Good Luck
