Lord Loh.
Full Member level 4
Signal Leaching...
This question comes from Circuit forums, I run it and did not get a satisfactory answer there. (Hope mods of this board do not mind)
I shall publish answers I get here on my forum, unless you explictly ask me not to do so. It would be good if you could give a contact method...
Is it possible to leach signals from a wire.
I suggest that we wind a wire around the target wire and tune the taping circuit to give a clear output of the flux that the coil is able to capture the signal...
Something similar to clamp tester...
Is this possible ? How can it be done ?
