NQ21HT449
Newbie level 6
Hello, I'm trying to replace a volume control IC that has 80 dB of dynamic range, but I think 66-70 dB would be enough for my application.
I don't have SPI bus, the device has to be fully analog and be controlled by a log potentiometer. MAX5440 is one of the few analog options, but only has 60 dB of dynamic range. I suppose I could build a comparator circuit to mute it when the potentiometer is at towards the end position, so my attenuation would jump from 60 dB to 90 dB. Shouldn't be a problem with hysteresis circuit.
I checked other chip manufacturers and their volume control ICs are fully digital as well. Are there any other options, other than running a SPI line or creating a glue CPLD logic to translate log pot to digital? Can I somehow cascade two MAX5440 to extend their range?
Do I even I need a volume control IC if I could build the similar circuit with op-amps?
