levnu
Full Member level 2
i use AD8031 and i wonder if its possible to deisign as mentioned in the title,
the reason is becuase i want the op amp to bias a PA Vgg that must be negative,
my op amp input is a DAC Voltage between 0 to 2.5V (i want that at 0V input the opamp will output the most negative voltage, for DAC input to opamp =2.5V i want the minimal negative output, close to zero, i would also would like to have a equation for it and not only simulation as i have today)
Thanks,
Arye
Thanks,
Arye
