Is it possible to connect PSoC directly to ICE?
smartsarath2003
Member level 4
Member level 4
psoc clk
Hello,
Is it possible to connect PSoC directly to ICE. I have a small psoc target board,which is working when i connect it to ICE using pod and pod foot. With that idea, I employed a RJ45 connctor as well, on the PCB, conncted to data,clk,Vcc,gnd and Xres. I fallowed the same order as given by cypress in IDE user guide.
This time i conncted my PCb directly to ICE using cat5 cable. When I try to connect, I am getting a message that invalid silicon id,found 0, must be between 1-256..etc.
What else i need to adjust, to get it working. Apart from that it is working fine. I am using the CY3201-PD development kit for CY 26443 Psoc device.Can Any one plese help me with these...
Re: PSoC Help Please!!!
Double check your connections. Verify that your supply is noise free.
I have used similar configuration with this kit without any problems.
Regards.
