Re: Is it possible to real time video signal to 10kbps
correct me if i am wrong but XYZ algorithm is more computation expensive and it is an old algorithm of 80's. so there must be better algos available 8)
Re: Is it possible to compress real time video signal to 10k
I would look at the dvdr help forum . There is a codec there called KVCD. in svcd mode using TEMPG it is possible to comprese 3 houres on to a single cdr 80. not 10kbs but the best you will do with a watchable quolity.
May be you can find the info on vedeo phones -they used to send video in both direction via analog
PSTN access line . I have seen those , but at 10 Kb per sec quality is really bad even =when appeared on 100x200 resolution display .
I think it can reached at 10kbps in some condition, yet you shouldn't get good and big picture . the embalazer system in Isral researching on MPEG-4 tech are focusing on transmitting video&audio in GSM and GPRS network.
Hi volta
3D-DCT no doubt exploits both spatial and temporal (time-dimension) correlation but the hardware complexity increase due to requirement of video frames storage and processing.
