zhangljz
Member level 5
Hello everyone,
I am designing a classical PLL with a 2nd order loop filter, the reference clock frequency is 10MHz, VCO frequency is 40MHz ~ 350MHz, control voltage is from 0 to 1.2V.
I have a question about the loop filter. I use a poly resistor for the filter, but as we know the resistance of the poly resistor is varying regarding to process, temperature, etc. Do I need to make a programmable resistor, like several resistors in parallel switched by several signals, so I can program the resistance to have a roughly constant value.
This is my first time to design a PLL, I just want to make sure it is stable and locked.
Any advice is appreciated
