Is it neccessary to Power the MGT_ACCC/MGT_AVTT Pins?
Port Map
Full Member level 1
I want to know that, is it neccessary to Power up the MGT_ACCC/MGT_AVTT Pins on Virtex6 FPGAs?
I'll not use IOs FPGA in MGT Banks?
Hi Port Map,
If you want to access the particular Bank of SERDES, you need to power it accordingly.
Pls let me know if you need any other clarifications.
Thanks and Regards,
Shunmuga Sundaram S.G
I need No SERDES or DDR.
I need only LVCMOS or LVDS IOs.
So I think it is not neccessary to Power up the MGT_ACCC/MGT_AVTT Pins. is it ok?
Hi Port Map,
If you do not want to use the MGT Banks, then you need to Gnd all those TX and RX pins (This will be mentioned in "GTX/ GTH transceivers user guide" of the selected FPGA Series) and you you don't need to MGT_AVCC/MGT_AVTT pins .
And you cannot use those pins (MGT Banks) as LVDS / LVCMOS IOs.
I think u r clear with this.
Regards,
