maniac_xox
Newbie
PLease help, I am fairly new to proteus and mplabx so I am trying to udnerstand how it all works. I am using PIC18F452 microcontroller.
I have this circuit in proteus shown at the bottom of the text.
The code:
When Switch RA4 is pressed, the system flashes the 2nd and 3rd LEDs intermittently.
RA4 is the activate/deactivate switch as i understand, but since I changed it to RD4, as well as the settings that involve PORT/TRIS/LAT A to PORT/TRIS/LAT D, the LEDs keep flashing and the switch stops working. How do I fix that?
It's also requested that my RESET switch is connected to RC4, not sure how that works either as I am aware the MCLR pin is the one that resets the MCU? How can the RC4 pin reset the system?
Final issue, the first LED should only be on when the system is on, but if the power terminal isnt pesent they won't turn on at all..
Appreciate your help a real lot!
The code:
#define _XTAL_FREQ 4000000
//Set the config bits
#pragma config WDT = OFF, BOR = OFF, LVP = OFF, OSC = XT
// setting up BUTTONS
void InitialiseButtons(void);
unsigned char ReadButton(void);
#define UP 0
#define DOWN 1
#define BUTTON_S2 0x01
#define BUTTON_S3 0x10
#define BUTTON_S2_S3 0x00
TRISA |= 0x10;
TRISB |= 0x01;
//Detects a change of state of buttons
// Buttons are active low
char ButtonState;
static char ButtonFlag = 0x11;
//Read State of both buttons
ButtonState = (PORTA & 0x10) | (PORTB & 0x01);
if(ButtonFlag != ButtonState) //there has been a change
ButtonFlag = ButtonState;
return ButtonFlag;
return 0x11;
// setting up LEDs
#define LED0 0x01
#define LED1 0x02
#define LED2 0x04
#define LED3 0x08
void InitialiseLED(void); //prototype functions
void LEDOn(unsigned char TheLED);
void LEDOff(unsigned char TheLED);
void LEDToggle(unsigned char TheLED);
void LEDWrite(unsigned char LEDValue);
TRISB = 0xF0; //Set the port direction register
LATB = 0x00; //Clear the port
LATB |= TheLED; //Set the required bit on PORTB
LATB &= (~TheLED); //Clear the required bit on PORTB
LATB ^= TheLED; //XOR the required bit on PORTB
LATB = LEDValue; //Store a value on PORTB
// setting up TIMER
void ResetSeconds(void)
seconds = 0;
unsigned char TimerOverflow(void)
char flag = 0;
if(INTCONbits.TMR0IF)
INTCONbits.TMR0IF = 0;
//flag = 1;
seconds++;
//return flag;
return seconds;
// setting up STATEMACHINE with TIMER
enum
S_OFF
S_STATE1
S_STATE2
}States;
enum
E_T1,
E_T2,
E_BUTTON
}Events;
#define T3s 3
#define T5s 5
unsigned char GetEvent(void);
unsigned char State = S_OFF;
void DoStateMachine(void)
unsigned char Event;
Event = GetEvent();
switch(State)
case S_OFF:
LEDOff(LED3);
LEDOff(LED2);
if(Event == E_BUTTON)
ResetSeconds();
State = S_STATE1;
break;
case S_STATE1:
LEDOn(LED3);
LEDOff(LED2);
if(Event == E_T1)
ResetSeconds();
State = S_STATE2;
State = S_OFF;
break;
case S_STATE2:
LEDOff(LED3);
LEDOn(LED2);
if(Event == E_T2)
ResetSeconds();
State = S_STATE1;
State = S_OFF;
break;
if(TimerOverflow() == T3s)
return E_T1;
if(TimerOverflow() == T5s)
return E_T2;
if(ReadButton() == BUTTON_S2)
return E_BUTTON;
void main(void)
InitialiseLED();
InitialiseButtons();
InitialiseTimer();
Lcd_Init();
while(1)
DoStateMachine();
